DIY QuickDisk-emulator for MZ-800
Post by Jo Even » Thu Jan 03, 2019 11:33 am
Geir Øyvind has written an article about his MZ-800 QuickDisk-emulator on the website:
https://sharpmz.org/articles/the-mz-ser ... -emulator/
Re: DIY QuickDisk-emulator for MZ-800
Post by Pacman » Thu Jan 17, 2019 7:10 am
Very good.
Does this version read or / and write to a file in dsk (cpc) format?
Post by Jo Even » Thu Jan 17, 2019 10:09 am
Not sure what you mean, are you asking if the emulator can "mount" DSK-files and allow the MZ to access files within such a disk image? I can't see anything in the sources for the QD-emulator that allows this.
Post by Pacman » Thu Jan 17, 2019 4:05 pm
I have not looked at the sources yet, I should have started with that.
Theoretically, there should be no limit to embedding read / write files in dsk format in the QD emulator.
Post by hlide » Thu Jan 17, 2019 8:28 pm
I think the image are probably mzq (a format close to the image inside QD) but I may be wrong.
Post by Jo Even » Thu Jan 17, 2019 9:00 pm
The only way to do that would be for the emulator to treat DSK images as virtual QuickDisks, like it does with directories (on the SD-card) today. But I'm not sure why one would want to do this.
Post by hlide » Sat Apr 25, 2020 12:22 pm
The fact that MZ-800 is able to read/write QD through its ROM (unlike MZ-700) may a good indication that it should be possible if the emulated QD controller handles all the possibilities given by the Z8440 registers. A look at the arduino file shows there is that function "qdisk_write_byte_into_drive" and the contents seem to indicate that we can write in the image or in a mzf file of a virtual QD (folder).
