Homemade Basic Game
paranoid64
Homemade Basic Game
Post by paranoid64 »
My first basic game. Just wanted to know how the Basic is so under MZ-Sharp 700 Tickt ;)
Hong Kong Street(Basic) Download
Re: Homemade Basic Game
Is this just for S-Basic? I wonder if it can be converted to SA-5510 or SP-5025
http://mz-sharpworks.co.uk/
paranoid64
I do not understand myself now. I have use S-Basic MZ-5Z008 with Quick Disk support.
I thought that would be the only difference(QD support)?
paranoid64 wrote: Sun Aug 18, 2019 6:45 pm I do not understand myself now. I have use S-Basic MZ-5Z008 with Quick Disk support.
Well, a lot of the different BASICs have different tokens to represent the commands, so usually a converter is needed. Although I have just found that S-BASIC contains its own converter for the older BASICs.
paranoid64
How does the converter work?
S-BASIC will load an MZ-80 program and when it finishes loading it will say something like "CONVERTING TEXT......." and it converts all the BASIC tokens to S-BASIC ones. Then you can list and run the MZ-80 program with no problem.
But for the MZ-80 machines you usually have to load a separate converter program to convert between the different BASICs.
