CRT Chaser Field
CRT Chaser Field
New acquisition today. I will try and get an MZF of it and add to this post.
Re: CRT Chaser Field
Strangely it seems to contain two files of the same name (different lengths). I haven't worked out why yet as I haven't tried playing the game yet. Attached are the files.
CRT FIELD.zip
(4.98 KiB) Downloaded 1570 times
Pretty cool little game for a BASIC game. The 2nd file is a data file. Quite fast scrolling in the game for BASIC (presumably it has a bit of machine code in there somewhere)
missumj
Post by missumj »
I have the tape of MZ-80b version.
I recorded the wav file but can't convert to .mzf file (by tapeload.exe)
If someone can give me a help i will post the wav.
By the way how to run the MZ-80k version on emulator?
mz-80a wrote: Fri Aug 17, 2018 4:30 pm Pretty cool little game for a BASIC game. The 2nd file is a data file. Quite fast scrolling in the game for BASIC (presumably it has a bit of machine code in there somewhere)
And there is no snow on the screen of the MZ-80 K - unless you only tested on an MZ-80 A?
I believe there is MZF-Studio which can convert WAV<--->MZF in both directions. MZ-80B is supported.
https://www.ulrichkeller-it.de/DownloadBereich.html
I have used MZF Studio for many years. What's the issue?
And I don't know if there is any snow on the MZ-80K screen, sorry! I've not recorded any videos of the game...
hlide wrote: Mon Aug 27, 2018 12:04 pm I believe there is MZF-Studio which can convert WAV<--->MZF in both directions. MZ-80B is supported.
missumj
Post by missumj »
Well, here is the converted .mzt file of CRT Chaser Cosmic through MZF-Studio. Thank hlide.
I opened this with Notepad, seemed to be a BASIC game. Unfortunately it doesn't work.
Anyone help?
CRT ______ V.1.zip
(9.13 KiB) Downloaded 1278 times
I guess BTX means "Basic TeXt". Did you try to load from the Basic?
missumj
Post by missumj »
hlide wrote: Fri Aug 31, 2018 8:09 am I guess BTX means "Basic TeXt". Did you try to load from the Basic?
Tried under Toshiya Takeda's emulator with SB-5510, just got some messy codes.
