Token converter
Token converter
Has anyone got a way of converting from MZ-1200 BASIC to MZ-80A? The 1200 one is SP-5030 I think and MZ-80A's one is SA-5510.
Re: Token converter
Maybe we should write our own utility to convert programs between the different BASICs :)
sharpmz
Re: Token converter
Post by sharpmz »
Try SP-5030 on a 80a. As I remember, it should work. Tell me if I'm wrong, please.
You also can try the converter 80k to 80a:
https://sharpmz.org/mz-80a/dldutils.htm
Re: Token converter
I forgot to reply to this! Yes, it does seem to load on the 80A.
