DIsk Drive Cables
feltonissimo
DIsk Drive Cables
I have just aquired an MZ80B with disk interface. I already had a sharp double disk drive but do not have the cables need to connect the two. Does anyone know what cable I need and if there is somewhere that I can buy one from?
gregctaylor
Re: DIsk Drive Cables
I thought it was just a 34 pin TE connection, same pitch as an IDE ribbon off an old computer. Only snag is I think they had the missing pin (to stop you plugging in the wrong way around) at a different point but you can get the cables with all pins wired to get around that.
Try someone like RS Components or Mouser Electronics.
Greg
Greg
