MZ-80B project (Floppy Disk I/O Card cloning!)
dat-alex
Post by dat-alex »
hi!
It recently came to my possession a Sharp MZ-80b with MZ-FIO2 & a Custom printer like card.
Unfortunately, a floppy card is missing and I want to connect a floppy to my MZ80b in order to run some CP/M stuff!
As these cards are really rare nowadays I decided to make (clone) a DIY pcb from the schematic [url]http://web.archive.org/web/201509262024 ... 80b_sm.pdf
I would like to ask if someone has a better-scanned service manual or willing to make a hi-res scan of his mz80FI card in order to have it as a guide trying to guess... the low-res printed pins of the service manual.
Thank you in advance
Alex
tingo
Re: MZ-80B project (Floppy Disk I/O Card cloning!)
Post by tingo »
Unfortunately, I don't have a better manual, or a MZ-80b / floppy controller card.
Are you trying to redraw the schematic and do a new PCB layout?
Torfinn
dat-alex
Post by dat-alex »
Thank you tingo for your reply.
YES! that's exactly what I am trying to do.
MZ80b-FI cards are really rare I think and is the only way I can read/load CP/M on this machine -I think. :)
(With the help of some photos (found from the net) parts placement would be helpful and makes double sided autoroute works better I think.)
dat-alex
Post by dat-alex »
Still didn't managed to find an FDD interface card for my 80B.
Do you think that an Sharp MZ1E05 will be in any way compatible with MZ80B-FI Sharp MZ80b-FI ?
I know that MZ80b-FI card has no eprom and uses in-built IPL routines but do you think the rest of hardware will be compatible?
Alex ;)
MZ-1E05 (MZ-700/800/2000): Mini Floppy Disk Interface / Controller card ( MZ-1F19, MZ-1F02 )
tingo
Post by tingo »
There are several "layers" of compatibility requirements, like (this is not an exhaustive list):
- mechanical - does the card physically fit into the connector on the machine?
- electrical / signals - does the machine have the signals that the card requires (and vice versa) on the correct pins?
- logical / program - is the machine able to use the card correctly
You would need to check the various manuals, to figure out it that is possible.
Example: if the signals are the same, but the connectors / pinout are different, an adapter can be made.
Torfinn
dat-alex
Post by dat-alex »
Hi! Tingo
Thank you for a quick response my friend.
You are asolutely right about ALL you thioughts, Let me 'walk through' one by one to express my opinion on your thoughts:
No I think the card does not fit into MZ80B expansion box card holders
Yes I checked all signals are available (question about +5v supply) signal adapter needed
I think this is the main problem , my friend, of the whole concept
MZ80K , MZ80A, MZ700 etc are using an IPL program already in ROM that on booting first thing is to check $F000 for an FDD eprom booting routines.
SHARP MZ80B (according to manual) uses a different method. IPL only tries to boot from tape or FDD if present (Actually there is a small portion of code that checkes for the presence of FDD interface card and if not present passes control to tape loading.
So I think the main concept is to force MZ80B to load for example from external eprom found on MZ-1E05 external eprom.
OR patch te original onboard eprom with the correct FDD code to access external card!
I will do so when I find some more spare time!
As pinout os different (checked) adapter is needed.
tingo
Post by tingo »
Well, then you also need to check the code in the MZ-1E05 eprom, and figure out:
- where in the address map does it live?
- are the routines in there compatible with the MZ80B ROM routines?
So just more work for you, I'm afraid.
Torfinn
dat-alex
Post by dat-alex »
Thank you both of you! for the infos.
I think this is a a long term project.
I will inform you af any proggress....
