[MZ-80 K / MZ-80 A / MZ-1200] DRAM failure: how to replace 4116 by 4164
French source: Remplacement de la RAM du TO7.
4116 chips are not reliable DRAM as they tend to be fragile and die probably because they need three voltages: +5, -5, +12.
Not only that, they are more and more difficult to find and not that cheap. On the other hand, 4164 are easier to find, less expensive and less fragile. And they only need +5V.
As a fact, MZ-80 K and MZ-80 A are using 4116 and I had to replace some defective DRAM on my MZ-80 K. At that time, I had to buy 24 x 4116 chips to be sure to cover all the needs.
So there is no reason we cannot do the same DRAM replacement as TO7 for our favorite MZ.
Here is the schematics about the differences between 4116 and 4164:
Note that 4164 are 64Kbit and not 16Kbit so the MZ will use only a quarter of memory. For this, pin 9 (A7 which doesn't exist in 4116) is set to Vcc. We also need to disconnect pin 1 (Vbb -> NC) and pin 8 (Vdd -> NC) from the motherboard so there is no -5V and +12V rampaging around the DRAM:
Then to connect the pins 8 and 9 to Vcc (+5V) so pin 8 can get +5V:
If you don't want to modify the sockets, you can simply bend the pins 1 and 8 of the DRAM chips so those pins won't be inserted in the socket, making them not connected.
Sharpals
Re: [MZ-80 K / MZ-80 A / MZ-1200] DRAM failure: how to replace 4116 by 4164
Post by Sharpals »
Yes it runs, i have done that 1987 :-) SO you can ubgrade, lower RAM MZ80
