MZ-800 Unicard help
MZ-800 Unicard help
Hi, so my Unicard arrived for my MZ-800. I am a bit new to all this so looking for an idiots guide to getting the best of it. I looked online for instructions but they are a bit lacking.
Got dsk images down. It now boots happily into basic. But I am trying to work with other image types and am having some issues.
1) How do you use games that have multiple .mzf files? You can run one from the menu but I don't see a way of running others once the first one runs.
2) How do you set the RTC? Is it via ethernet or USB?
As always, thanks in advance.
Re: MZ-800 Unicard help
I fear I cannot tell more about. The usage I have for Unicard is a little limited (no RTC, no ethernet - everything through SD). What you want looks like a tape queue where you queue the MZF files in the wanted order (that's a thing we can find in MiSTer SharpMZ of P. Smart). I'm not sure whether Unicard has such a facility.
Martin8bity
Post by Martin8bity »
1) It is not possible to run multifile MZF, as there is not direct tape emulation nor ROM hack used. But most of the games I know that are multifile are converted to single file version. Which game do you try?
2) The easiest way to set RTC is the web interface through Ethernet. You can also use the UniUSARTShell over USB. The RTC is not used much on current firmware. There will be a new one soon with FTP and lot of other improvements, just contact me, if you would like to try the beta.
There is a lot of information about Uniard on https://www.sharpwiki.cz
Martin's 8-bit blog
www.8bity.cz
