[SHARP MZ-80 K/K2E/K2/C, 80 A, 1200] DRAM Tester ROM
This is the link to the source and releases of DRAMTester ROM image so you can detect the DRAM chips in failure.
Link to source.
Link to releases.
charminator
Re: [SHARP MZ-80 K/K2E/K2/C, 80 A, 1200] DRAM Tester ROM
Post by charminator »
Hmmmm ... i do not understand how to use the code ?
i can download an *exe, but this doesn't make sense.
Do i need to replace my system rom against *what* ?
Could you please declare how you got upper screen ? I would like to check my spare chips :D
Collecting -K- since 1978
Supporter of Karl Heinz Maus famous MZ site ;)
1) Retrieve IPL.ROM in Assets of the last release : https://github.com/SHARPENTIERS/MZ-80K- ... r/releases. Just click on IPL.ROM to donwload it.
2) Burn the IPL.ROM image on a 4KB (E)EPROM.
3) Plug this (E)EPROM in the M-ROM socket after removing the M-ROM chip.
4) Launch the MZ-80 K and it will start the program. The first screen will be garbage to tell you the screen is okay and displays.
5) Then a "PacMan" intro displays and waits for you to press [SP] to start the four tests.
6) The first three tests are fast and the last one is slow. For each DRAM chips numbered from #1 to #24, there are 4 pills or crosses to tell the result for each tests. A pill means successful and a cross means a failure on the chip. On the motherboard, you have three rows (they are showed as columns I, II and III on the program). Each row has 8 chips.
7) Once you write down the chips having a cross at least, you switch off the MZ-80 K to replace the defective chips by new chips then you jump to step 4 back.
8) Congrats! all the chips are working. You can now put the original M-ROM back in its socket.
charminator
cool, many Thanks ;)
Have you taken a 2732 or an 2532 for your tests ?
I didn't test myself but it was successfully tested by Ben Koffer on his MZ-80 A and by a Japanese beta-tester who owns several K models: K, C, K2 and K2E.
If you don't have 2332, you'll need an adapter 2332->2732 and a TL866ii plus as a programmer.
One link for an assembled one for instance : https://www.sellmyretro.com/offer/details/36272. For the same seller, you can also get a DYI kit instead.
charminator
Using an 2532 eprom is easier ;)
I will try and report
