[MZ-80A] Pixel Finder V1.0
When I was making my short demo "1000 FOLLOW" I needed a quick way to find patterns of pixels within the CGROM. I created this utility to help me do this. You can plot a pattern of pixels and it will search the whole CGROM for you to find that pattern of pixels. It will then tell you which character in the CGROM it found the pattern in and on which of the 8 pixel rows it found that pattern.
At the moment it's quite basic but it does contain some useful functions. When you load the program just press the CR / ENT (Return) key to find instructions. I do hope to improve the program at some point.
Hope someone will find it useful!
PIXEL FINDER V1.0.zip
(2.14 KiB) Downloaded 1884 times
Re: [MZ-80A] Pixel Finder V1.0
I should have mentioned that there shouldn't be any issues running this on the MZ-80K or MZ-700 either.
