I am still looking for a physical MasterDisc for the -A- and a tool which is capable to create Master Disc copies usable as new masters
Also looking for SUC Utility 2.0 or any other good copy/transfer tool for the -A-
Can exchange against floppies for the -k for which i am perfectly equipped
Offer P&P plus a fee for handling ?
WTB: 5.25 Utilty Discs for Sharp MZ-80A
Forum rules
1. No auctions, fixed price only.
2. Update your post when you've sold/bought the item.
3. Most importantly - be nice.
charminator
Collecting -K- since 1978
Supporter of Karl Heinz Maus famous MZ site ;)
Re: WTB: 5.25 Utilty Discs for Sharp MZ-80A
Yep, okay, I will use my SU COPY to take a copy of my master disk and send to you. I have the original disk so it shouldn't be too much trouble. In fact, I think it's possible I already have a copy I took ages ago hanging around. I'll check.
May I suggest that you place the MZ80K versions of SUCopy on to the disk/s if you have them, so that that they can be saved to tape on the MZ80A and reloaded by the MZ80K
I don't believe I have the K versions.
Here are the MZ80K (71) versions of SUCopy, could you please copy them on to the MZ80A disk, as I do not have any working disk dirves.
- Attachments
- KSC71T35.zip
- (6.28 KiB) Downloaded 2433 times
- KSC71T40.zip
- (6.28 KiB) Downloaded 2399 times
charminator
i received SUCOPY for the -A- and Utility 2.0 meanwhile so i can offer to send floppies if needed
Will try to get the upper files to my -k- via audio, many many thanks
